Matthew M Posted January 6, 2023 Share Posted January 6, 2023 Hi, I have a project where the substrate of the external wall changes along the length of the wall. I have an issue where the floor slab won't bind to the wall substrate after the second change. I have 2no. questions: 1 - Which wall join tool do I need to use to join 2no. wall styles with different substrates? 2 - How can I bind the slab to the wall substrates and ensure the bounding is retained? I have attached an image below for information. Any input would be appreciated. Thank you Quote Link to comment
M5d Posted January 7, 2023 Share Posted January 7, 2023 Where you have the two wall styles end to end, you can use the corner (L) join mode. I tested your example though (in 2022), without using a join, and the slab tool still worked . . . so maybe check both Wall Styles have the same / desired Wall Components selected as their Core. Quote Link to comment
M5d Posted January 7, 2023 Share Posted January 7, 2023 Couldn't edit my post for some reason; scratch the above, you have multiple sections of the same wall style, they'd all be wrong if it was the Core. Quote Link to comment
Tom W. Posted January 7, 2023 Share Posted January 7, 2023 23 hours ago, Matthew M said: Hi, I have a project where the substrate of the external wall changes along the length of the wall. I have an issue where the floor slab won't bind to the wall substrate after the second change. I have 2no. questions: 1 - Which wall join tool do I need to use to join 2no. wall styles with different substrates? 2 - How can I bind the slab to the wall substrates and ensure the bounding is retained? I have attached an image below for information. Any input would be appreciated. Thank you I generally always have Manual Bound Slabs. When I try to make an Auto-Bounded Slab where the Walls change style midway as per your example I always end up with a Slab which is 'Auto-Bounded with Manual Edges'. Someone else will confirm but it may not be possible to have an auto-bounded Slab with that configuration of walls...? You might be compelled to set the edge offsets manually (which like I say is what I generally do anyway). 1 Quote Link to comment
Matthew M Posted January 11, 2023 Author Share Posted January 11, 2023 Tom W. Many thanks for your comments, this appears to be a workflow I can use. 1 Quote Link to comment
