matteoluigi Posted January 5, 2023 Share Posted January 5, 2023 Hi, I guess, the only option I can use in the IFC_ExportNoUI(path) command is the path. For all other options I will need the command IFC_ExportWithUI, am I right? Quote Link to comment
Vectorworks, Inc Employee Mihail Rizov Posted January 5, 2023 Vectorworks, Inc Employee Share Posted January 5, 2023 Hi @matteoluigi, Yes, that was the intention. In order to setup layer mapping and options, it is not necessary to make an export - open IFC Export, setup all and press Save Settings. Regards, Mihail Rizov Quote Link to comment
matteoluigi Posted January 5, 2023 Author Share Posted January 5, 2023 7 minutes ago, Mihail Rizov said: open IFC Export, setup all and press Save Settings hm, ok. When I start scripting, I want to control as much as possible from the script. so, imo there should be way more options, including the option of using the saved settings, of course, too. (like IFC_ExportNoUI(path) with no options -> saved settings) Quote Link to comment
matteoluigi Posted January 5, 2023 Author Share Posted January 5, 2023 32 minutes ago, Mihail Rizov said: open IFC Export, setup all and press Save Settings. that worked. However I wonder, because all settings should have been saved due to already in the past executed ifc-exports... Obviouosly you need to click the "save settings" button, too. Quote Link to comment
Vectorworks, Inc Employee Mihail Rizov Posted January 5, 2023 Vectorworks, Inc Employee Share Posted January 5, 2023 @matteoluigi, 16 minutes ago, matteoluigi said: that worked. However I wonder, because all settings should have been saved due to already in the past executed ifc-exports... Please, do not forget to save the document after IFC Export. Quote Link to comment
matteoluigi Posted January 5, 2023 Author Share Posted January 5, 2023 (edited) 26 minutes ago, Mihail Rizov said: save the document after IFC Export. or save and commit including document settings... We also created a new project file in order to get that settings in the vwxp-file. damn, I guess, that those settings don't survice a Project Sharing commit... Edited January 5, 2023 by matteoluigi Quote Link to comment
matteoluigi Posted January 5, 2023 Author Share Posted January 5, 2023 well, in a project sharing document you need to: 1) open IFC Export, setup all and press Save Settings 2) save a copy as vwx file 3) create a new vwxp file from that vwx file (committing document settings obviously doesn't commit ifc-export settings) 😞 Quote Link to comment
