MartinBlomberg Posted January 3, 2023 Share Posted January 3, 2023 Hi, I struggle to make an image fit on a wide LED screen. It's a square image and I want it centered on the LED-screen. Even though I've unchecked "Tile Image" boxes (Horizontal and Vertical) the image tiles. Since the size of the LED most likely will vary I don't want to have different files. Can someone help me figure this one out? Thanks! Quote Link to comment
C. Andrew Dunning Posted January 3, 2023 Share Posted January 3, 2023 7 hours ago, MartinBlomberg said: I struggle to make an image fit on a wide LED screen. It's a square image and I want it centered on the LED-screen. Even though I've unchecked "Tile Image" boxes (Horizontal and Vertical) the image tiles. Since the size of the LED most likely will vary I don't want to have different files. First: The way that the tool works is that, in the Edit Array Image dialog, 100% scaling means that the image fills the width of the given screen/array. If resulting image is than taller than the screen/array, a portion of the image is then not seen/used. You can use "Vertical Shift" to specify what portion of the image is seen/used. Second: The Spotlight version of the tool only automatically tiles the given image. The Landru Design version of the tool adds a "Tile Image" toggle to the above dialog, allowing you to do things like reduce the scale so that you see the entire "taller" image on a wiser screen, center the image (using Horizontal Shift) and not tile the image, as below: Does that answer your question? Quote Link to comment
MartinBlomberg Posted January 5, 2023 Author Share Posted January 5, 2023 Thanks! I think it answers the question, but do I have to buy a plugin for this specific feature then? Warm regards, Martin Quote Link to comment
C. Andrew Dunning Posted January 5, 2023 Share Posted January 5, 2023 10 minutes ago, MartinBlomberg said: do I have to buy a plugin for this specific feature then? Yes. Quote Link to comment
