LarryO Posted December 30, 2022 Share Posted December 30, 2022 Here is a titleblock manager that relies upon an instance of the title block being on a specified sheet. It uses the data you enter in that titleblock to fill in the blanks of all subsequent pages and it also uses the sheet name and number to populate two fields unique to each sheet. There is a manual revision counter that goes up to 94 and down to E. You can set a date that doesn't change on specific sheets. It requires you to toggle the revision or date function to update the date field to the current calendar date or any changes to sheet name etc. There is also a note option which is currently populated with finish options that can be changed to show other information by rewriting the pull-down data set in the plugin. You can also change the name of the default sheet that the manager looks for by changing the text stored in the plugin string data #3000. The default sheet's name and the string text must be identical. Only the first instance of the plugin on the default sheet will be recognized as the parent data set for all the other sheets. If the first is deleted the manager will look for another but failing that if no instance is present or no sheet exists with the specified name then the management script will not function. The script uses the term GRAST to identify the primary instance so that NAME will not be available to use for other items/objects. Have fun. Larry TBDataManager.vso BasicTitleBlockSetup_4_TBManager.vwx Quote Link to comment
