Sam Jones Posted December 24, 2022 Share Posted December 24, 2022 Is it possible to place a Locus, or any other object, in a symbol definition/ I can get a handle to a symbol definition. I can iterate through the objects in the definition. I can edit those objects. But, I cannot find a way to place a Locus or any other object inside a symbol definition. Anybody know how? Quote Link to comment
Vectorworks, Inc Employee Julian_Carr Posted December 24, 2022 Vectorworks, Inc Employee Share Posted December 24, 2022 Did you try SetParent() Sam? 1 Quote Link to comment
Sam Jones Posted December 24, 2022 Author Share Posted December 24, 2022 My problem is that I need to set the location of the object, so I need to place the object using the coordinates of the definition. How do I do that? Quote Link to comment
Pat Stanford Posted December 24, 2022 Share Posted December 24, 2022 Once you have used SetParent, then the coordinates of the object are "translated" into the Symbol Def local coordinate system. So just move it to where you need it to be. Procedure Test; VAR H1, H2 :Handle; B1 :Boolean; BEGIN H1:=GetObject(GetSymName(FSActLayer)); Locus(0,0); H2:=LNewObj; B1:=SetParent(H2,H1); HMove(H2, 2',2'); End; Run(Test); If you have the Locus in the relative location of a symbol instance, then get the location of the Locus and the location of the Symbol Instance and calculate the offset between the two and use that to move the locus after you set the parent. 1 Quote Link to comment
Sam Jones Posted December 25, 2022 Author Share Posted December 25, 2022 Nope. Sorry Pat. The above does not work. Quote Link to comment
MullinRJ Posted December 25, 2022 Share Posted December 25, 2022 @Sam Jones, Just remember that the (0,0) point inside a symbol definition is the Symbol's Insertion Point. In Pat's example, and you place the Locus outside the Symbol and want it in the same relative position inside the symbol, move the Locus by MINUS the symbol's insertion point. Try this. PROCEDURE xxx; { Move Locus into a Symbol at the same position as it was outside the symbol. } { Place a symbol, place a locus, select both, run script. } VAR Hsym, Hsdef, Hloc :Handle; Psym :Point; BEGIN Hsym := FSActLayer; Hsdef := GetObject(GetSymName(Hsym)); Hloc := LSActLayer; GetSymLoc(Hsym, Psym.x, Psym.y); if SetParent(Hloc, Hsdef) then begin HMove(Hloc, -Psym.x, -Psym.y); ResetBBox(Hsdef); SysBeep; { make noise when done } end; { if } END; Run(xxx); Are you writing code that needs to work if the User Origin is shifted? If so, I could write a lot more on how to manage coordinates between Drawing Layers and Symbol Definition spaces. If you also want your code to work in Rotated Plan View (ugh), I can help you there, too, but you'll need a good night's sleep and a large bottle of Aspirin. Merry Festivus 😉 Raymond Quote Link to comment
Sam Jones Posted December 25, 2022 Author Share Posted December 25, 2022 (edited) Nope. Sorry Raymond. Your example doesn't work either. I noticed that your code does not place the locus, so I put in code to do so, but the following code does not work. SetParent() fails without triggering the alert. I tried the code below without the HMove(), and still no Joy. SetParent() seems to be the problem. No locus shows up anywhere in the symbol. The code was run from a text file .vs. PROCEDURE Test; VAR SymHdl :HANDLE; SymDefHdl :HANDLE; LocHdl :HANDLE; X, Y :REAL; BEGIN SymHdl := FSActLayer; SymDefHdl := GetObject(GetSymName(SymHdl)); GetSymLoc(SymHdl, X, Y); Locus(X, Y); LocHdl := LNewObj; IF SetParent(LocHdl,SymDefHdl) THEN BEGIN HMove(LocHdl, -X, -Y); ResetBBox(SymDefHdl); END ELSE AlrtDialog('SetParent Fails'); END; RUN(Test); Edited December 25, 2022 by Sam Jones Additional info Quote Link to comment
MullinRJ Posted December 25, 2022 Share Posted December 25, 2022 @Sam Jones, Hope you're having a relaxing day, VS problems aside. Your code (and my code) works on my system. Are you using 2D or 3D Symbols? There is a difference. Raymond Quote Link to comment
Pat Stanford Posted December 26, 2022 Share Posted December 26, 2022 If you have a Hybrid Symbol and want the Loci to show in the Top/Plan view. you are going to have to set that for it also now that the "2D" portion of symbols is no longer controlled by Screen Plane objects. Look at AddObjectTo2DComponentGroup and Get2DComponent Group in Objects-Custom. These seem to apply to both Symbols and PIOs. Merry Christmas. 1 Quote Link to comment
MullinRJ Posted December 26, 2022 Share Posted December 26, 2022 Hey @Sam Jones, What @Pat Stanford said, AND, is your User Origin Shifted? If it is, you also have to remove that distance from the equation. From your comment, "SetParent() seems to be the problem.", have you verified that you have a handle to the two objects in question? I have never had a problem with SetParent() if the handles are valid and of the correct type. Also, be careful mixing objects of different types – Screen Plan, Layer Plane, and 3D objects. Mixing them will affect their visibility in different views. You know, you could make this a whole lot easier if you'd post a file with your symbol in it. There's a lot of guessing going on here. I hope you're grading us on a curve. Merry Christmas to All, and to All a good night. 🙂 Quote Link to comment
Jesse Cogswell Posted December 27, 2022 Share Posted December 27, 2022 @Sam Jones I think your code is working, but it's placing the locus inside the 3D component of the symbol. The way I usually combat this is to force the planar object (such as the locus point) onto the screen plane by using SetObjectVariableBoolean(<object handle>,1160,TRUE). I understand that the screen plane is considered deprecated, but it is still what Vectorworks uses to differentiate objects in the 2D component compared to the 3D component of a hybrid symbol. And forcing an object onto the screen plane with this script will not trigger the "Enable Legacy Features" flag to get set. The script below will place a locus inside the given symbol at X: 1", Y: 1" while also correcting for the User Origin being different than the Internal Origin. Confirmed working in VW2023. PROCEDURE TestLoci; CONST kSymbol = 'Test Symbol'; kScreenPlane = 1160; VAR hSymbol,hLocus:HANDLE; BSB:BOOLEAN; Origin:POINT; BEGIN GetOriginInDocUnits(Origin.x,Origin.y); hSymbol:=GetObject(kSymbol); Locus(1-Origin.x,1-Origin.y); hLocus:=LNewObj; BSB:=SetParent(hLocus,hSymbol); SetObjectVariableBoolean(hLocus,kScreenPlane,TRUE); ResetObject(hSymbol); END; Run(TestLoci); Quote Link to comment
