Aqueous 0 Posted January 21, 2006 I have recently moved over to version 12 and found that when I create a door plug in and subsequently render, the wall rendering cuts out a portion of the wall to either side of the frame. I switched back to version 11 and found that it does not happen and when I import feom 11 to 12 the same occurs. Is this a bug or am I doing something wrong. Quote Share this post Link to post
islandmon 2 Posted January 21, 2006 Check out this Topic which includes the excellent example images & discussions: Radiosity problem examples (long post) Quote Share this post Link to post
CipesDesign 76 Posted January 21, 2006 Aqueous, I beleive what you are seeing is a bug. If so, I bet it will be fixed soon. Quote Share this post Link to post
Jershaun 8 Posted January 24, 2006 This has got to be a bug. I did a test of a room with walls and rendered. Then I deleted the walls and created a solid (Extruded subtraction) and re-rendered using the same settings. The results are in the link below. I hope this problem is sorted out. http://www.freeimagehosting.net/d029a89822.jpg Also when symbols are inserted in walls, when rendered, lines appear to join the corners of the symbol and wall. Quote Share this post Link to post
islandmon 2 Posted January 24, 2006 Kinda makes one wonder how this obvious bug made it past the 'beta' filtration system and into the pool. Prior to release didn't anybody bother to test the v12 Window&Door PIO in walls and then render the results ? It's stuff like this that makes my skin crawl ... cus there's no way to fix it with out endless fudging over it ( which defeats the purpose of the PIO symbols ). For my money every PIO should at least be able to perform the basics which include I/O presentation impeccability. This is not an "almost is good 'nuf " proposition. Quote Share this post Link to post
Aqueous 0 Posted February 7, 2006 Thanks all I'll switch back to citting the apartures from the wall for the time being. Here's looking forward to receiving the bug fix. Quote Share this post Link to post
Dave Donley 148 Posted February 7, 2006 Hello Aqueous: Please send me the file at dave@nemetschek.net. What render mode is this? Quote Share this post Link to post
Aqueous 0 Posted February 10, 2006 Hi Dave I have sent 2 copies of a file under seperate email. One is in v11 and V12. The same process for each drawing is drawing a wall and placing a door plug in and then viewing with renderworks. The corruption occurs with all modes of render. Cheers Quote Share this post Link to post
Dave Donley 148 Posted February 10, 2006 Hello again Aqueous: This is a known bug in 12.0.0, and will be fixed in an upcoming maintenance release. I am trying to find out what the specific configuration is for this bug and what the workaround would be. Sorry for the problem, [ 02-10-2006, 10:03 AM: Message edited by: Dave Donley ] Quote Share this post Link to post
compusam 0 Posted March 1, 2006 The windows PIO in VW 12.0.1 is flawed (and possibly the door PIO as well). I do not think that it is productive for VW users to suck on eggs apologizing for their complaints. I bought VW 12 which is TOTALLY USELESS because of this bug. I am continuing to "work" with VW 11.5, but my confidence in upgrading in the future has been unalterably flawed. Quote Share this post Link to post
Dave Donley 148 Posted March 1, 2006 Hello Aqueous: I just re-tried your files with 12.0.1 and they render correctly now. Quote Share this post Link to post
