Thomas W Posted December 20, 2022 Share Posted December 20, 2022 Hi all, The vectorscripts and codes are new to me but bring an interesting and complementary vision to the different possibilities! We work with 1 basic file which contains about 15 modules then we have 15 separate files for the manufacture of each module. I'm looking for the best way to keep all elements of these 15 files up to date with the base file (symbols, database format, labels...). So I searched in VS:Function_Reference and tested some scripts like BuildResourceList, BuildResourceListN, GetNameFromResourceList, ImportResourceToCurrentFile, Name2Index... The 1st objective would be to replace from an open file the elements present in this open file by the elements of the same name of the base file. The 2nd objective, if it is feasible, would be to replace the elements of several files which are each in different folders, by the elements of the same name of the base file. I did several tests but I have trouble with certain functions or loops. I manage to make a list of the open file and a closed file by indicating the path, to import a symbol according to its name, to find its index according to its name, but I can't get it all to work whole. Since I couldn't get the Procedure CallBack from VS:ImportResToCurFileN to work I tried another way, if anyone has an explanation or another example than how to help the Callback function I want Well! Below is a test script and the file attached: Salut à tous, Les vectorscripts et les codes sont nouveaux pour moi mais apportent une vision intéressante et complémentaire aux différentes possibilités! Nous travaillons avec 1 fichier de base qui contient environ 15 modules puis nous avons 15 fichiers à part pour la fabrication de chaque modules. Je cherche le meilleur moyen de garder tous les éléments de ces 15 fichiers à jour par rapport au fichier de base (symboles, format de base de données, étiquettes...). J'ai donc cherché dans VS:Function_Reference et j'ai testé certains scripts comme BuildResourceList, BuildResourceListN, GetNameFromResourceList, ImportResourceToCurrentFile, Name2Index... Le 1er objectif serait de remplacer à partir d'un fichier ouvert les éléments présents dans ce fichier ouvert par les éléments de même nom du fichier de base. Le 2ème objectif, si c'est réalisable, serait de remplacer les éléments de plusieurs fichiers qui sont chacun dans des dossiers différents, par les éléments de même nom du fichier de base. J'ai fait plusieurs tests mais j'ai du mal avec certaines fonctions ou certaines boucles. J'arrive à faire une liste du fichier ouvert et d'un fichier fermé en indiquant le chemin, à importer un symbole suivant son nom, à trouver son index en fonction de son nom, mais je n'arrive pas à faire fonctionner le tout ensemble. Vu que je ne suis pas arriver à faire fonctionner la Procedure CallBack de VS:ImportResToCurFileN j'ai essayé d'une autre manière, si quelqu'un à une explication ou un autre exemple que celle de l'aide de la fonction Callback je veux bien! Ci-dessous un test de script et le fichier en pièce jointe : VS11:BuildResListN_List vers ListN_modifs-FORUM PRESQUE OK-2 : PROCEDURE testGetNameFromRes; {$DEBUG} VAR resTypeN: INTEGER; fullPath: DYNARRAY[] OF CHAR; resListN, resList: LONGINT; numResN, numRes, i: INTEGER; S1: STRING; h: HANDLE; {numIndexN, numIndex: LONGINT;} {resourceName: DYNARRAY OF CHAR;} {Exists: BOOLEAN;} BEGIN resTypeN:=16; resList:=BuildResourceList(resTypeN, 0,'', numRes); AlrtDialog(CONCAT('Nombre d''éléments de la Liste=', numRes, Chr(13),'ID pour la Liste=', resList)); BEGIN FOR i:=1 TO numRes DO IF GetNameFromResourceList(resList, i)='My Symbol Name' THEN BEGIN AlrtDialog(CONCAT('Symbole déjà présent dans ce fichier')); END {ELSE AlrtDialog(CONCAT('Symbole non présent dans le fichier, on va l''importer du fichier source'));} END; fullPath:='Y:\Thomas\Vectorscript Exemple\TW VScript Create list of symbols in resources\TW_VS créer un rectangle_rectangleN_GetBBox_sur bureau COPIE.vwx'; resListN:=BuildResourceListN(resTypeN, fullPath, numResN); AlrtDialog(CONCAT('Nombre d''éléments de la ListeN=', numResN, Chr(13),'ID pour la ListeN=', resListN)); BEGIN FOR i:=1 TO numResN DO IF GetNameFromResourceList(resListN, i)='My Symbol Name' THEN h:=ImportResourceToCurrentFile(resListN, i); END; BEGIN IF GetObject('My Symbol Name')<>NIL THEN AlrtDialog(CONCAT('Symbole présent dans ce fichier')); END; END; RUN(testGetNameFromRes); Thank you and I hope the google translation will be understandable enough! Have a nice day and happy Christmas! Thomas Merci et j'espère que la traduction google sera assez compréhensible! Bonne journée et bonnes fêtes! Thomas TW test Create List Symbols and Import_Forum.vwx Quote Link to comment
Thomas W Posted January 3, 2023 Author Share Posted January 3, 2023 Hello and all my best wishes for this new year! I'm trying to figure out how the ImportResToCurFileN function works. According to the explanation of the help, we should be able to choose between Don't import, replace or rename? I tried based on the helper script but when importing an already existing symbol, I can't seem to make this choice appear. The example below is from the help, is it supposed to work or is something missing? : Bonjour et tous mes meilleurs vœux pour cette nouvelle année! Je cherche à comprendre comment fonctionne la fonction ImportResToCurFileN. D'après l'explication de l'aide lors de conflit on devrait pouvoir choisir entre DoNotImport, Replace ou Rename? J'ai essayé en me basant sur le script de l'aide mais lors de l'import d'un symbole déjà existant je n'arrive pas à faire apparaître ce choix. L'exemple ci-dessous vient de l'aide, est-il censé fonctionner ou il manque quelque chose? : https://developer.vectorworks.net/index.php/VS:ImportResToCurFileN PROCEDURE testResCountSymFolders; VAR resList : LONGINT; numRes : INTEGER; h : HANDLE; FUNCTION ImportResCallback(VAR resourceName:DYNARRAY OF CHAR) : INTEGER; BEGIN AlrtDialog( resourceName ); resourceName := Concat( resourceName , '-1' ); ImportResCallback := 2; END; BEGIN { list symbol folders in curr doc } resList := BuildResourceList(16, 23, '', numRes ); h := ImportResToCurFileN( resList , 1, ImportResCallback ); alrtDialog(concat('numRes=', numRes , ' h=', h)); END; RUN(testResCountSymFolders); Thanks in advance and have a nice day! Merci d'avance et bonne journée! Quote Link to comment
Thomas W Posted January 4, 2023 Author Share Posted January 4, 2023 17 hours ago, Thomas W said: Quote Link to comment
Thomas W Posted January 4, 2023 Author Share Posted January 4, 2023 (edited) Just now, Thomas W said: Edited January 4, 2023 by Thomas W Quote Link to comment
