At the request of @Matt Panzer a wishlist item, spun off from a discussion thread.
Basically: I think confusion arises around what "structural objects" are, as defined for the purpose of section viewports and the various options in the "Advanced Section Properties" dialogue. But this wishlist item goes a little further I think. I am going to try and keep this concise to start with, partly to stop it being too confusing, partly because I'm running out of time to write this just now.
Here's that dialogue box:
I have attached a VWX file with this post. It'll probably be necessary to open it and look at it in order for this post to make any sense. Screenshots are taken from it. The array of possible section viewports looks like this:
Each of those section viewports is a section through this hypothetical wall/roof buildup:
That's a standard cavity wall here in the UK, brick outer skin (not loadbearing), insulation in cavity, block inner skin (loadbearing). I've modelled a kind of decorative brickwork corbel at the top of the brick. The roof is structural timber joists, plywood deck on top, insulation & membrane above. Plasterboard ceiling fixed to bottom of joists. Decorative coving at junction of wall and roof, internally. What I've drawn is just illustrative for the purposes of this wishlist post.
Most of my section drawings (in practice) are either
- something like section type B where I want to show some level of internal buildup detail, and where the scale is 1:50 or larger. In these examples I've shown material fills as solid colour, but in reality I would usually be using hatches instead.
- something like section type E where I don't want to show buildup detail. Anything smaller than 1:50 will usually be like this. Sometimes I might use it up to 1:50 for early stage drawings.
Points to make:
Note the difference between section types A and B:
On section type B the brick corbel detail is "merged" with the brick component of the wall. I'm more likely to want this, than the lines shown in section type A. I've achieved this by telling VW that those extrudes I used to model the corbel courses are "structural objects" because this allows it to merge them with the "structural object" that is the wall. But of course, those corbels aren't in reality "structural objects" at all.
What are/aren't defined as "structural objects" for this purpose doesn't make sense to me. Either VW has got some wacky ideas about what's structural (ie holding the building up), or that's just a bad name for that type of object, or there needs to be some additional method(s) of choosing what to merge in sections.
Below, section type F on the left shows what VW thinks is and isn't structural. Section type G on the right shows what I think is and isn't structural.
Then we come to what the "profile line" is. I actually haven't really used this in real life. I'd assumed it was the outer profile of the whole section...but it seems it's not. A complication is that it doesn't seem to work in VW2023 SP2. So... here's a screenshot from VW2021 to show where it is drawn (as the red line) in section type C :
But in section type D I indicate (by using stacked viewports) where I think a "profile line" should be and would be useful, and, I think, fits with a fairly standard drawing convention where the overall section cut line is drawn with a thick line (I've just shown it in red for emphasis) and then the internal detail (also in section) is drawn with a thinner line:
Ok, I'm going to leave it at that for now, no doubt multiple subsidiary questions will come up in discussion.
I do think the way that sections are drawn (and the amount of fine control given to the user) is really crucial in allowing us to create good, clear documentation from the model with as little touching-up in annotation space as possible.
line-weight
Points to make:
VWsections.vwx
Edited by line-weightLink to comment
41 answers to this question
