extruded polygons don't map textures
tamarindi
Hi,
This is a problem i have since 11.5. Sometimes extruded polygons can not be texturized. I couldn't find much consistency because sometimes it works and sometimes not. I always check that the polygon is a closed shape, i also tried to convert to nurbs - but nothing helps.
The strange thing is that actually the texture does apply on the object info, but when i enter the mapping mode it's like nothing is in there, and the preview shows the basic fill color.
Any suggestions?
Thanks
[ 12-20-2005, 07:23 AM: Message edited by: tamarindi ]
Select 3D Poly >enter Group ... look at the OIP make sure the "closed' check box is selected. For complex polys you may need to decompose then join line segments ( especially arc2line ) then recompose making sure that there are no object handles within object handles... only the 4 or 6 bounding handles are highlited.
As for NURBS > convert to surface
