Jiajing Posted December 14, 2022 Share Posted December 14, 2022 Building a Dialog with TextPopup, and I have PRESENTATION VALUES with that textpop. However, after exporting to python, how would I still retian those values. I notice those info are included in the section of 'XML defintion of the layout' . how would the main dialog code retreive data from 'XML defintion of the layout' Thank you Quote Link to comment
JBenghiat Posted December 14, 2022 Share Posted December 14, 2022 Presentation values are merely for seeing a mock-up of the dialog with Dialog Builder. You still have to code the dialog handler. When testing the dialog with DB, you can see the temporary code in your user folder, which can serve as a guide for developing your handler. You can also use DB to save additional strings that you can use for your options, which is useful if you intend to localize your plug-in. Quote Link to comment
