Change OIP drop-down sort order?
Infrequently I need to incorporate structural steel into our designs. Depending on the situation, I'll use the 2D and/or the 3D Channel, I-Beam, Wide Flange or one of the tubing options. I've long been frustrated that the largest sizes are listed first when we only use the smaller sizes. For example, rectangular tube starts at 30x24x.5 and wide-flange beam starts at W44x335. Every time I use these tools, I have to scroll nearly to the bottom of the (thorough and impressive!) list.
I'm guessing the 2D, 3D and Structural Member tools all use the same list since they're identical.
Is there a way to simply flip the sort order on the sizes?
