Skyfox01
How does VRML Export works?
Hello,
I tried to get VRML Exports out of a Vectorworks drawing. But each file I tried to export has 0 Bytes and opening on Explorer is not possible!
What do I wrong during Export?
Can anyone help me?
Thank you.
Kind regards,
Skyfox01 [Confused][Confused]
VRML in v11.5.1 works great ...
There are 5 tricks to it:
1) Adjust the screen size , I usually reduce it to 500x375, 4:3
this reduces the file size
2)Create a 3Dpoly with zero thickness&zero fill which averages the overall perimeter of the object.
3) Render in FinalQuality Renderworks
4) Default setting work great but create 102 frames , adjust lower vertical angle to limit frames.
5) Set up html wrapper to include Object code (forum wont let me show it):
VRML saves as a .mov file and must be embedded if it is to be viewed via browser otherwise it must be downloaded then viewed via QT.
Here's the example embedded:
DiscoBall VRML
View as 'source' in IE to get at the Object codings.
Hope this helps.
