Carol Reznor Posted December 6, 2022 Share Posted December 6, 2022 Hi Is there a reason why that Layers which are Georeferenced do not rotate along when changing the Orientation (angle to true north)? It is something I would expect georeferenced layers to do automatically. This would make it possible to change the geo-orientation of all georeferenced objects and not the objects on non-georeferenced layers. Now this option seems to be impossible: you either select 'Do not transform' or 'All (transform/move&rotate)'. What exactly is the difference then between layers checked as geo-referenced and others which are not? Thanks! Quote Link to comment
