neurain Posted December 6, 2022 Share Posted December 6, 2022 I would like to know if there are any restrictions on NDI output in Vision. And we definitely need a manual to deal with NDI. I want to demonstrate multiple outputs. Quote Link to comment
Vectorworks, Inc Employee bbudzon Posted December 6, 2022 Vectorworks, Inc Employee Share Posted December 6, 2022 I'm not sure if this answer your question, but there isn't any licensing restrictions for NDI Output out of Vision. There are functional restrictions, however. What I mean by this is that if you check the "Send NDI Stream" checkbox, the only stream Vision can send is a stream of the "main" viewport. In single viewport mode, this is the only viewport. In multi-view mode, it is the bottom right viewport. This was primarily implemented to work with Disguise's EVO feature. But, you could also leverage NDI Output out of VIsion to, say, stream realtime Vision rendering to another computer or television. If you are asking about receiving NDI Streams into Vision, then yes; there are licensing restrictions. You get as many NDI Input Streams into Vision as you have DMX Universes in your license. Other than that, it is not restricted in any way functionally. So, you can apply those NDI Streams as textures in your scene however you'd like. Quote Link to comment
neurain Posted December 7, 2022 Author Share Posted December 7, 2022 I'm using Vision Unlimited. Then there is no universe limitation in the fixture and there is no problem using NDI at all? Quote Link to comment
Vectorworks, Inc Employee bbudzon Posted December 7, 2022 Vectorworks, Inc Employee Share Posted December 7, 2022 Correct! You can input/receive an unlimited number of NDI streams. When we were implementing outputting/sending NDI streams out of Vision, we felt it was only necessary at that time to output the "main" viewport (as described above). I hope this answers your question! Quote Link to comment
