Heblon Posted December 5, 2022 Share Posted December 5, 2022 Hey there, I often struggle with -I guess most of you do it with ease- the basic dataflow stuff. I am fmailiar with the 'user interaction' nodes but in this case I have no idea how to deal with it: I simply want to chek if my 'loft surface' node did create a solid shape. If not I want to show an 'altert inform'. It seems that there is data (data passing) even is there is no result (no visible/ resulting solid 3D geometry) Any advice? I am sure that you can help me with that, as you always do! Thanks in advance! Quote Link to comment
Marionette Maven Marissa Farrell Posted December 5, 2022 Marionette Maven Share Posted December 5, 2022 I would use a Valve node to suppress the display of the dialog. You may need to modify this a little (possibly a pop front node, or just comparing the first value in the outputs of Loft Surface) I'm not positive without creating a full-fledged test file, but I believe the "Int" node should be set to 113 (for surfaces) Let me know if this doesn't work/if you need more guidance. 1 Quote Link to comment
Heblon Posted December 6, 2022 Author Share Posted December 6, 2022 Thank you! That worked pretty well for me. The handle type is 84. Quote Link to comment
