Bruce Kieffer Posted December 5, 2022 Share Posted December 5, 2022 What might be stopping Vectorworks from placing a 3D loci in my file? The 3D loci works on a blank document. Quote Link to comment
0 Andy Broomell Posted December 5, 2022 Share Posted December 5, 2022 Vectorworks Preferences: (Indeed, that warning message could be more helpful) 2 Quote Link to comment
0 markdd Posted December 5, 2022 Share Posted December 5, 2022 Theres a setting in Vectorworks Preferences under the display Tab. Display 3D Loci. There are 3 options available. Hopefully that will solve the problem. 1 Quote Link to comment
0 Bruce Kieffer Posted December 5, 2022 Author Share Posted December 5, 2022 (edited) Yep! That's the solution. Now I have to delete all of them that I placed trying to make it work!!! Thank goodness for the select similar tool, but darn that does not work on them, but custom selection does. Edited December 5, 2022 by Bruce Kieffer 1 Quote Link to comment
0 rDesign Posted December 5, 2022 Share Posted December 5, 2022 (edited) 1 hour ago, Bruce Kieffer said: Thank goodness for the select similar tool, but darn that does not work on them, but custom selection does You don't have your Select Similar Preferences set correctly, as the Select Similar tool does work on 3D Loci. Make sure you have 'Object Type' selected under Other Attributes. Edited December 5, 2022 by rDesign Quote Link to comment
0 Bruce Kieffer Posted December 5, 2022 Author Share Posted December 5, 2022 (edited) 2 hours ago, rDesign said: You don't have your Select Similar Preferences set correctly, as the Select Similar tool does work on 3D Loci. Make sure you have 'Object Type' selected under Other Attributes. Hum... That is the setting I am using, and Select Similar DOES select 2D loci, but NOT 3D loci. I tested in a blank document too. OK, I tested some more. It takes a bunch of clicking to "hit" the 3D loci in some spot different than just highlighted to get the Select Similar tool to select them all. Edited December 5, 2022 by Bruce Kieffer 1 Quote Link to comment
Bruce Kieffer
5 answers to this question
