gov_colin Posted September 15, 2005 Share Posted September 15, 2005 Simple question: I set up a batch render for an overnight rendering job. When I came back in the morning, a message on the screen reads "Could not export file due to lack of memory." Granted, it's a huge model that has two entire buildings glommed together on one file, but I'm working off a dual 2.2ghz processor with a gig of ram. Is my computer telling the truth? Or is it just a big lazy lier like my ex-girlfriend? gov Quote Link to comment
islandmon Posted September 15, 2005 Share Posted September 15, 2005 The Render process requires both RAM & virtual memory for the spool file(s). Perhaps the virtual partition is too small.Usually you need at least 3-5x the file size ! Since the processor(s) can only render line by line and not the entire image, 1-2gb RAM is more than adequate depending on DPI of final image ( use Activity Monitor to show the processor/memory stats during render ). Quote Link to comment
DDDesign Posted September 15, 2005 Share Posted September 15, 2005 Yes, I think it's telling the truth - and I've had the same experience. From my understanding, the computer needs a lot more memory to render than just the size of the file. Try decreasing your export or sheet resolution. Quote Link to comment
gov_colin Posted September 15, 2005 Author Share Posted September 15, 2005 Cool. I'll turn down the recursion level I guess, or just make the size a little smaller. Thanks both Quote Link to comment
Kaare Baekgaard Posted September 16, 2005 Share Posted September 16, 2005 Sometimes when I do batch renderings, some of the output jpegs are cropped with a white 'frame', which is a real pain... Gov, I think you may want to consider which objects are clearly visible in the renderings, and which are not. I often have two versions of the same symbol objects - one for the foreground and one for the backround. It gives you the option to economize with the memory. By creating a couple of extra classes, you can also hide away a lot of surplus objects, that are not visible in the individual rendering. Quote Link to comment
