As we move more and more into the use of networked fixtures, vectorworks should evolve to allow this and the following changes should be made to the Lighting Device.
Changes:
- Make User fields a check box that shows user fields once active
- Make shutter options a check box that shows only when active
- Generally de-clutter the lighting device info and make alot of it "drop downs" as most of these items are only used in select cases.
- Allow custom input in "Fixture Mode" where there is not an existing fixture profile in vision or a GDTF fixture available.
alfie1706
Changes:
Addition:
- IP Configuration section containing:
- IP Addresss
- Subnet Mask
- Protocol (MANet, sACN etc)
0 answers to this question
