bjoerka Posted December 1, 2022 Share Posted December 1, 2022 Is there any way to have own saved views to be accessible with shortcuts? In my case - i have a rotated ifc model and every time i zero on the numberkeypad the rotation gets set to zero degrees... but front / left and so on correspond to the rotated plan view... annoying... Quote Link to comment
Pat Stanford Posted December 1, 2022 Share Posted December 1, 2022 No and Yes depending on how standard your Saved View names are and how much work you are willing to do. No. there is no standard way to assign shortcuts to saved views in VW. Yes. Saved views can be called from scripts. Scripts can be made into PIO Menu commands. PIO Menu Commands can be added to a workspace and given a shortcut. How many saved views do you need? You will probably need a separate PIO Menu command for each saved view. Ask again if you would like help in setting this up. Quote Link to comment
bjoerka Posted December 1, 2022 Author Share Posted December 1, 2022 Thank you Pat. Any help is appreciated .-) Actually it´s the only thing that i want to change to the top 2d view without having the rotation to be reset. My saved view is called Top_Rotated, but i think that is not really important .-) I looked in the POI and found a procedure called vrestore - which i think is the tool to do it - but then i am stuck... If you can help, that will be georgous! Quote Link to comment
Pat Stanford Posted December 2, 2022 Share Posted December 2, 2022 Take a look at these two guides on How to Create a Menu Command and How to Add a Command to a Workspace and Assign a Shortcut. SST-Make a PIO Menu Command.pages.pdf SST-Add a Command to a Workspace.pages.pdf 3 Quote Link to comment
bjoerka Posted December 2, 2022 Author Share Posted December 2, 2022 What shall i say... Works like a charm! I think i need to get deeper into that scripting thing after using that software since 1994 😉 Thanks a lot for that brilliant tutorial, Pat! 2 Quote Link to comment
