Hamish Posted November 28, 2022 Share Posted November 28, 2022 Hello! I have a bunch of angled trusses (so 3D only symbol) which when i try to convert to a hanging position will no longer display in plan view (however it will before i convert) Is this a bug? or is there a way to get the 3D geometry to display in Plan view? Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted November 29, 2022 Vectorworks, Inc Employee Share Posted November 29, 2022 Hi Hamish which version of VW are you using? If you make the trusses a Hanging Position before you rotate them then this should work fine. If you make the trusses a a HP after you have rotated them then you should still get a wireframe appearance of the truss object. If its truss symbols you have imported or created then these would have to have a 2d component prior to making a HP. I am using 2023 SP2 Quote Link to comment
