Hamish Posted November 28, 2022 Share Posted November 28, 2022 Hello! Is there a way to insert a connection between a Pipe and an ANGLED truss? I have several raked trusses in my plan and have pipes sat accross them horizontally at 90 degrees for lights to out rig from. I would (obviously) like to connect these to the truss for load calculations however when trying to use the insert connection tool i get the error "Tilted rigging objects can't be stacked" I can use the insert drop tool however thats not how the pipes are being attached. My annoying work around is to group the pipe and lights together (for easy selection) and putting an equivelent point load on the truss but i have to remember to deselect the groups when performing calculations (slightly tedious when there's 12 of these spread out through the drawing) Thanks! Hamish 1 Quote Link to comment
Cristiano Alves Posted March 28, 2023 Share Posted March 28, 2023 (edited) Up... I have the same problem with some lasers. I'm just draw on project, but after that for calculations I use a [Rigging Tools] -> "Rigging Load" with the weight insert manually, in the same point of the fixtures will be to hang. I think we don't have another way for now 😞 Edited March 28, 2023 by Cristiano Alves Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted March 29, 2023 Vectorworks, Inc Employee Share Posted March 29, 2023 Currently this is a basic limitation of Braceworks, the reason behind it is that none of the clamp manufacturers could or would provide us with structural data for how the clamps behaved when not used horizontally.There is a work around (kinda), create a hanging position combing the truss and attached pipes, this will enable it to calculate, though I'm not 100% sure about how accurate the calculation will be Quote Link to comment
Cristiano Alves Posted March 29, 2023 Share Posted March 29, 2023 40 minutes ago, jcogdell said: create a hanging position combing the truss and attached pipes Can you explain how we can make it? Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted March 29, 2023 Vectorworks, Inc Employee Share Posted March 29, 2023 Ah I've just retested this workaround and it looks like it no longer works, sorry for the mistake. Instead you will have to add a point load to represent the load of the pipe acting on the angled truss. 1 Quote Link to comment
