livespace josha Posted November 28, 2022 Share Posted November 28, 2022 I can probably figure this out with a bunch of guess-and-check and restarting, but I'll try a more direct route! I have a file with all of my pre-formatted and configured devices, and want to store it in my communal workgroup folder. When I select the device tool, and use the symbol mode, I can select a folder location from the window that pops up. Where should I put my device file so it appears here, rather than just opening it or favoriting it? Quote Link to comment
Pat Stanford Posted November 28, 2022 Share Posted November 28, 2022 I am sure someone on the CC team will answer, but I think it is in Libraries:Defaults:ConnectCAD:Device. You should be able to drop a standard VWX file containing your devices into that path within the Workgroup Folder and they should be seen and useable. You may need to restart VW after adding the file as I think VW only checks on original opening. Or it may only take a click on Refresh Libraries from the Gear Icon in the Resource Manager. I can never remember which. Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted November 29, 2022 Vectorworks, Inc Employee Share Posted November 29, 2022 Hello @livespace josha, Currently we do not have any default content with device symbols and there is no specific location that the tool can import symbols from. So for now you will have to proceed with the favorites workaround. I will create an enhancement request about this so that we can consider it. Thanks for your feedback! 🙂 Best Regards, Nikolay Zhelyazkov Quote Link to comment
livespace josha Posted December 1, 2022 Author Share Posted December 1, 2022 @Pat Stanfordthanks for the "Refresh Libraries" tip! I'll give that a try, because restarting VWX while sorting out workgroup libraries is a pain! @Nikolay Zhelyazkovthanks, I appreciate you adding that to the request list for future versions. Quote Link to comment
wscooper Posted April 5, 2023 Share Posted April 5, 2023 (edited) Is this implemented yet? Workgroup support for custom devices, cable types and connectors would be most useful. Just tried, appears it is! Although it appears to be read only? Edited April 5, 2023 by wscooper Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted April 6, 2023 Vectorworks, Inc Employee Share Posted April 6, 2023 13 hours ago, wscooper said: Is this implemented yet? Workgroup support for custom devices, cable types and connectors would be most useful. Just tried, appears it is! Although it appears to be read only? - Hello @wscooper, Yes, workgroup data cannot be edited from within vectorworks. If you want to set up workgroup data you can first add it as user folder data and then move the created file from the user folder to the workgroup folder. Best Regards, Nikolay Zhelyazkov 1 Quote Link to comment
Jeremy Best Posted June 8, 2023 Share Posted June 8, 2023 On 4/6/2023 at 7:03 PM, Nikolay Zhelyazkov said: Yes, workgroup data cannot be edited from within vectorworks. For clarification, Nikolay are you referring only to ConnectCAD data? Because I can open files that are stored in my Workgroup folder, edit, then save them in-place. Even so, editing files saved in the Workgroup folder might be bad practice because a) it might prevent other user's from browsing this file's content while it is open, and b) if all users of the Workgroup folder did this practice then two user's might edit it at the same time. Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted June 8, 2023 Vectorworks, Inc Employee Share Posted June 8, 2023 5 hours ago, Jeremy Best said: For clarification, Nikolay are you referring only to ConnectCAD data? Because I can open files that are stored in my Workgroup folder, edit, then save them in-place. Even so, editing files saved in the Workgroup folder might be bad practice because a) it might prevent other user's from browsing this file's content while it is open, and b) if all users of the Workgroup folder did this practice then two user's might edit it at the same time. - I was referring to ConnectCAD data as it is stored in txt files and not vwx files and we provide UI in Vectorworks to edit these files in the user folder directly from Vectorworks without having to open these files in text editor and having to know how to edit/format them. Quote Link to comment
