When walls on separate layers are aligned and using the same surface hatch, rendering in hidden line in 2023 SP3 displays the line at the top/bottom of the respective walls between layers.
Observations:
Nvidia is set at the default GPU
Testing in a new, blank file in 2023 SP2 yielded the same results
Works as designed in 2022 SP5
Works as designed in 2023 SP1
NVIDA GPU Drivers up to date
Windows updates are up to date
PS. Thanks for adding the ALT+Click > 'Change Version' to the Updater allowing me to roll back my version and keep working on SP1.
Ned Flanders
Observations:
4 answers to this question
