Drawing a building from plans
JMA_Team
Put each floor on a separate layer and set up the Layer Heights so they stack properly.
Based on your question, you probably want to spend a couple of hours at Vectorworks Universtiy learning the basics before you jump in. It will save you time and aggravation in the long run.
https://university.vectorworks.net
Search for Building, Classes, Beginner. and look at at least "The Basics".  You may also want to look at "Stripped" and if this is more that a side hobby, "Core Concepts", but that will take longer to get through.
Although, I think those are all designed for more recent versions than 2019.  The concepts are the same, but the interface if probably different.
I would exactly recommend as Pat said.
When you are more familiar you may want to finally setup
a VW Stories and Level System and control your BIM Object's
Stiles for each Component separately by Level Z assignments.
But for now, just set Layer Heights.
And also look for tutorials how to create 3D Models from/over
2D Drawings. Or how to refine 3D from starting withVolume Models
or preliminary designs. VW is pretty comfortable doing this.
