Ceiling - Light Fixtures no longer overlay grid
Shortnort
For some reason I can not get my 2x4 light fixture to lay over the grid.  Is there a setting somewhere that I am missing?
I have a solid fill for the 2D symbol - the same as previous projects, but since upgrading to 2022, it doesn't seem to work properly.
14 answers to this question
Pat, thanks for trying to help.
View is Top/Plan View.
Yes to Snap to Grid.
The grid does NOT align with Snap Grid - the ceiling grid origins almost always are centered into the room or offset 1' in order to have aesthetic ceiling grid layout.
I copied and pasted a ceiling from another job, used the light fixture as in my problem case and it worked perfectly.
I created a test grid, inserted the light fixture and it worked perfectly.
So one may ask - why not create another grid...  Well - this is a 3 story building over 50,000 sf in size.  I may be forced to redo all of the grids, but I sure hope there is a much simpler and time effective way to get this to work.
Perhaps I've misunderstood but is it not just a case of sending the symbol to front (or Ceiling Grid to back)?
Lights and grid are on different layers.  The only way I can make it work is to delete the grid and put in a new grid.
I am still hoping that someone knows of a simple fix so that I don't have to do the complete building over. - MUCH time not anticipated.
Is the new Ceiling Grid on the same layer as the previous one or have you put it on a different layer? What I mean is did you originally have the light fixture on a layer that was below the ceiling grid layer in the stacking order + now you've changed this?
I have not changed anything... The layers, heights, visibilities, symbols, grid types, etc. are the same.  Using the existing grids (the entire building is effected/infected) will not allow the fixture to "overlay" the grid.  I even tried changing the symbol, fill, etc., to no avail.  I have tried changing the origin.  The only solution I have found is to delete the grid and reinstall the grid and it works like a champ.
The reason I did all of the grids to begin with wa to allow me to send dwg to MEP consultants to locate their ceiling penetrations.
Very disappointing that I have to redo the whole building, but what better things to do over Thanksgiving?
Thanks, Pat.
I do not know how to send a "subset" that you are asking for.  This is a pretty large file with 3 stories and really need some guidance to do what you have asked for.
Perhaps when I generated a dwg export, some "glitch" occured.  Wierd.
Thanks, Pat.
Thanks, I will do that.  But first, I thought I would share this...
I moved the original grids to a new class Ceiling Grid 2.
I created new grids on the original class and it worked fine.
I deleted everything on the new class (select all - delete).
Whe I tried to delete the new class I got the following message...
It si strange since everything in the class had been removed.  So - I think that is a clue as to what is happening.
