JMA_Team Posted November 21, 2022 Share Posted November 21, 2022 I want my Vectorworks sliding door symbol to look like the image attached. How do I achieve this? Any advice is appreciated. Quote Link to comment
Kevin K Posted November 21, 2022 Share Posted November 21, 2022 You can use 'Windoor' to achieve that...which became available in VW 2022, so if you have an earlier version you would have to suck it up and make a custom door...which is a royal pain :-). To install Windoor in VW 2022 it is done through the 'Help' Menu item: "Install Partner Products" Then you place the door in the wall and use the door option for "Parallel Door System'( right or left) and select how many doors you want within the opening, and Voila! 2 Quote Link to comment
Jonathan Pickup Posted November 21, 2022 Share Posted November 21, 2022 I highly recommend installing Windoor Quote Link to comment
rDesign Posted November 21, 2022 Share Posted November 21, 2022 (edited) If you're using Vw2023 you can now do this using the standard Door Tool, without using WinDoor. On the Door Setting General tab: Select 'Sliding' configuration, 'Multiple' operation and set your desired Leaf Number: Edited November 21, 2022 by rDesign 3 Quote Link to comment
Kevin K Posted November 21, 2022 Share Posted November 21, 2022 Good to know...I have not migrated to 2023 as yet. So...another good option to procure what JMA-Team wanted to do. 2 Quote Link to comment
