Ramon PG Posted November 17, 2022 Share Posted November 17, 2022 Can Door features and Space finishes be selectable as Wall components are? Ex: select all doors with glass leafs; select all spaces with x floor finish. Quote Link to comment
Pat Stanford Posted November 17, 2022 Share Posted November 17, 2022 The Select Similar tool does not allow specific Field Values to be used as part of the selection. But this could be an interesting Wish. The Custom Selection menu command can select objects based on records and field values, so you could relatively easily create a Custom Selection Script that would select doors with glass leafs etc. 1 Quote Link to comment
Ramon PG Posted November 17, 2022 Author Share Posted November 17, 2022 54 minutes ago, Pat Stanford said: The Select Similar tool does not allow specific Field Values to be used as part of the selection. But this could be an interesting Wish. The Custom Selection menu command can select objects based on records and field values, so you could relatively easily create a Custom Selection Script that would select doors with glass leafs etc. Thanks, I'll check on that. Quote Link to comment
