Maxon Redshift Texture Errors
Hi!
I am testing Redshift rendering engine and I have some problems with textures on LED screens in Spotlight.
I have file with 3 led screens. One renders OK, but other two renders with errors. Same file rendered with Redshift disabled - everything is OK.
Any ideas? All textures on screens are set to exactly same parameters.
Bad rendering in attachment
12 hours ago, Dave Donley said:
Hello @pgorski1984 I will need to look at the file to tell what is going on, can you DM this to me through the forum messaging?  I will not use it except for debugging this issue.
I've sent you the file. If you find what causes rendering errors - please write it here so more VW users will know what mistakes we sholud avoid.
