Ramon PG Posted November 14, 2022 Share Posted November 14, 2022 My schedule is too large and won't fit in the Sheet Layer. How can I split it? Thanks. Quote Link to comment
rDesign Posted November 14, 2022 Share Posted November 14, 2022 Assuming your Door / Window schedule is a worksheet, place the worksheet on a Design Layer, and create multiple Sheet Layer Viewports as needed. 2 Quote Link to comment
Pat Stanford Posted November 14, 2022 Share Posted November 14, 2022 Or edit the criteria of the schedule to make multiple smaller schedules that you can then put side by side. But this only makes sense if there is a reasonable way to break up the list. Ask again if you need more help. 2 Quote Link to comment
Ramon PG Posted November 14, 2022 Author Share Posted November 14, 2022 5 hours ago, Pat Stanford said: Or edit the criteria of the schedule to make multiple smaller schedules that you can then put side by side. But this only makes sense if there is a reasonable way to break up the list. Ask again if you need more help. Interesting, I'll try it by floors, then. Thanks all for the suggestions. Quote Link to comment
