AWDC LAO Posted November 12, 2022 Share Posted November 12, 2022 Hello, Version 2022 running fine on a MacPro 5.1 BigSur 11.7.1. V2023 installs perfectly, the program also starts up, but just before the workspace should appear the software crashes. With V2023 viewer, there is no problem and nothing wrong. Indeed I work on MacPro 5.1, but it has been modernized by Mac specialists in the Netherlands to current standard standards to run BigSur. Amazing isn't it? Unfortunately, although the minimum requirements are BigSur, the hardware meets the requirements as indicated on Nemetscheck's website, things go awry. Mac Pro Model-ID: MacPro5,1 Processorname: 6-Core Intel Xeon Processorspeed: 3,46 GHz # processors: 2 Totale aantal cores: 12 L2-cache (per core): 256 KB L3-cache (per processor): 12 MB Hyperthreading-technology: activated RAM: 96 GB 2x 3x16GB Systemfirmware: 9144.0.7.6.0 SMC-version (systeem): 1.39f11 SMC-version (processorlade): 1.39f11 Serie nr (systeem): CK12405PEUH Hardware-UUID: 581B0B24-3A72-5CB6-AC1F-F22C4B8AA2EE UDID: 581B0B24-3A72-5CB6-AC1F-F22C4B8AA2EE System Integrity Protection: deactivated Thunderbolt-bus: GIGABYTE UID: 0x00ED2BA798325400 Routetekenreeks: 0 Firmwareversie: 23.0 Domein-UUID: 3777B4F9-7D7F-4E08-BB7C-207278A667FC Radeon RX 590: Chipsetmodel: Radeon RX 590 Type: GPU Bus: PCIe Sleuf: Slot-1 Breedte PCIe-baan: x16 VRAM (totaal): 8 GB Fabrikant: AMD (0x1002) Apparaatcode: 0x67df Revisiecode: 0x00e1 Metal-familie: Ondersteund, Metal GPUFamily macOS 2 Monitor : DELL UP3216Q: 3840 x 2160 (2160p/4K UHD 1 - Ultra High Definition) BIG SUR 11.7.1 2TB: 766 GB (765.995.180.032 bytes) Capaciteit: 2 TB (2.000.189.177.856 bytes) Activeringspunt: / Bestandssysteem: APFS Beschrijfbaar: Nee Negeer eigendomsrechten: Nee BSD-naam: disk9s5s1 Volume-UUID: 8D669847-578E-4C81-93DB-03AFCDCBCC7F Fysieke schijfeenheid: Apparaatnaam: Samsung SSD 970 EVO Plus 2TB Medianaam: AppleAPFSMedia Type medium: SSD Protocol: PCI-Express I hope the software developer will solve this major problem soon. I am also aware that VW2024 will not work under BigSur and I will then have to make an investment in hardware amounting to +/- 7000€. Quote Link to comment
Hanbo Posted November 13, 2022 Share Posted November 13, 2022 I have the same problem with my Mac Pro 5.1 I am wondering if the system specs aren't quite right and you need an intel chipset that runs avx. Cinema 4d and redshift most recent release will not run due to this requirement. Quote Link to comment
AWDC LAO Posted November 14, 2022 Author Share Posted November 14, 2022 What you say is true for CINEMA4D, but nowhere is it written in the hardware specifications that AVX is necessary for VW. Then how do you explain that I can boot and use the viewer version ? I agree it is a stripped down version, but still. It would be very harshly unsympathetic to exclude this type of Mac. Quote Link to comment
rDesign Posted November 14, 2022 Share Posted November 14, 2022 (edited) If you haven’t already, I would send in the Crash Logs to Vw and see if they can offer any assistance. Edited November 14, 2022 by rDesign Quote Link to comment
Hanbo Posted November 15, 2022 Share Posted November 15, 2022 Just had this from VW which worked for me Rename the Cineware folder to something like Cineware OLD, from /Applications/Vectorworks 2023/Cineware Quote Link to comment
Vectorworks, Inc Employee Dave Donley Posted November 15, 2022 Vectorworks, Inc Employee Share Posted November 15, 2022 Since this is a Mac Pro 5,1 like Hanbo, renaming Cineware folder is the workaround here as well @AWDC LAO We will work to detect the absence of AVX and avoid the crash. All Renderworks functions, textures, etc will be off. Was not expecting AVX to be a factor so I did not include it in the system requirements for 2023. These computers are older than what we have available to test in-house. https://support.apple.com/en-us/HT202888 1 Quote Link to comment
AWDC LAO Posted December 5, 2022 Author Share Posted December 5, 2022 Dear, will there ever be an SP version for the MacPro's 5.1 that do not support AVX. My MacPro 5.1 works perfectly with version 2022 under BigSur. Too bad there was no announcement from the software developer, that AVX support is absolutely necessary. The problem is in the CineWare folder which is structured differently. The integration of RenderWorks and Redshift runs differently in VW2023 ! I know that the close cooperation between CPU and GPU is important for fast rendering and so it will be a necessity in the long run. It would please many if there is a subversion of VW2023 that runs for one more year on older computers. That way we are able to look forward to a new Mac. Today, most new MacPro's or Mac Studio are hard to come by with the effects of the conflict in Ukraine. Translated with www.DeepL.com/Translator (free version) Quote Link to comment
Johan de Groot • LYVR Posted December 5, 2022 Share Posted December 5, 2022 Yes same here. Please fix this! Quote Link to comment
Johan de Groot • LYVR Posted December 5, 2022 Share Posted December 5, 2022 6 Mac pro’s 2010 working perfect with vw2022, but not with 2023 Quote Link to comment
Johan de Groot • LYVR Posted December 5, 2022 Share Posted December 5, 2022 And not planning to buy a newer Mac Since these Mac pro’s are perfect machines! Quote Link to comment
Jim J Posted January 5 Share Posted January 5 Is it possible to verify or have a list of which Mac Desktops and MacBook Pros are compatible with VW 2023 without having to investigate the processor capabilities. The VW site seems to list M1 Apple processor a lot, but a lot of people are not able to afford the most current Macs, naturally. Thank You. Quote Link to comment
david on orcas Posted January 21 Share Posted January 21 I discovered the same crashing problem on my MacPro 5,1 running on Martin Lo's version of Open Core with Big Sur. Changing the name of the Cineware folder, did finally allow VW 2023 SP2 to open, however, textures wouldn't render at all. Updating to SP3, a new Cineware file was created and I was able to open VW 2023, however still had texture rendering issues:( (VW 2022 works fine.) Quote Link to comment
Eric Mousse Posted May 13 Share Posted May 13 (edited) Hi, I have the same problem with my Mac Pro 5.1 and Big Sur, but renaming the Cineware folder doesn't change anything, VW 2023 doesn't launch. Any ideas? (VW 2023 SP4) Edited May 13 by Eric Mousse Quote Link to comment
