Anders Blomberg Posted November 12, 2022 Share Posted November 12, 2022 I'm building a network and am trying to use a "atan"-node. It seems however that whatever I try I can't get a proper output from the node. I tried feeding it with both int, real and dim numbers, but always get the same error, as shown below. I brought in a math friend and he believes there might be an error in the code, specifically a part called bComplex, but we don't know how to edit the node so we couldn't try our hypothesis. Anyone know if there is a bug in the atan node or if I'm missing something? @Marissa Farrell perhaps? 1 Quote Link to comment
Marionette Maven Marissa Farrell Posted November 12, 2022 Marionette Maven Share Posted November 12, 2022 Yes, there's a missing line of code. In the #inputs section, add bComplex = self.Params.bComplex.value You'll also need to delete the first line in the script that begins with #COMMAND This has already been fixed for next service pack. 2 Quote Link to comment
Anders Blomberg Posted November 12, 2022 Author Share Posted November 12, 2022 54 minutes ago, Marissa Farrell said: Yes, there's a missing line of code. In the #inputs section, add bComplex = self.Params.bComplex.value You'll also need to delete the first line in the script that begins with #COMMAND This has already been fixed for next service pack. Thanks for confirming! I’ll wait for the next update then. 1 Quote Link to comment
