Bill_Rios Posted November 9, 2022 Share Posted November 9, 2022 Hey Hive Mind, I'm taking over a drawing for another drafter and I would like to replace the unstyled title blocks with a style. I was thinking this would be a good task from a worksheet, but of course the Title Block Border:Style is not one of those editable fields in VW Worksheets. Any thoughts on how to accomplish this without going to every sheet and manually updating the style to each TBB? Report criteria attached below. Please and thank you! Quote Link to comment
Tom W. Posted November 9, 2022 Share Posted November 9, 2022 You can do this very easily from the Title Block Manager. Select the Sheets you want the changes to apply to then select the styled TBB you want to use from the 'Use Style' drop down. 4 Quote Link to comment
Boh Posted November 9, 2022 Share Posted November 9, 2022 You can also use the custom modification command in the tools menu. Also very easy. Set the criteria to choose the titleblocks in the file you want to replace then where it says style in the dialogue window (yours will say “unstyled”) click on replace and select the style you want to use. 3 1 Quote Link to comment
Bill_Rios Posted November 9, 2022 Author Share Posted November 9, 2022 (edited) OMG this is my new favorite thing!!! I can see this significantly changing my workflow in a lot of ways! Thank you BOH!!!! Also the TB Manager is a great option Tom. Thank you. Edited November 9, 2022 by Bill_Rios 2 Quote Link to comment
