The Hamma Posted November 7, 2022 Share Posted November 7, 2022 I wrote a script to renumber viewports but I get a warning that the number has been used before. If Drawing coordination is turned off they no warning is displayed. So I tried to turn it off in the script and turn it back on at the end but it still gives the warning. Test file attached. {Script Name: VP Label (Consecutive) This script will renumber drawing labels contained within VP annotations in order picked by mouse. David Hamer, 2022 revision 11/7/2022} PROCEDURE NumberVPConsecutive; VAR numberStr : STRING; h,h2, anno, h1 : HANDLE; pX,pY : REAL; doorNumber,dummyVar,vpNumber : INTEGER; zoomis:LONGINT; DCPref:BOOLEAN; PROCEDURE SetVPNumber; BEGIN GetPt(pX,pY); if GetTypeN(h) = 122 THEN BEGIN {if h is a viewport} anno := GetVPGroup(h, 2); {creates group from annotations of selected viewport} h1 := FInGroup(anno); {selects the first object in the anno group} while h1 <> NIL DO BEGIN { steps through every object in the viewport selected by the click} if GetObjectVariableString(h1, 1166) = 'Drawing Label' THEN BEGIN {if veiwport object is a drawing label} SetRField(h1,'Drawing Label2','Drawing',numberStr); {VW 2021 Version sets the drawing label to the current active number in sequence} vpNumber := Str2Num(numberStr); { convert number string to number.} numberStr := Num2Str(0, vpNumber + 1); {subtract number from sequence then convert number to string.} ResetObject(h1); END; h1 := NextObj(h1); {get next object in viewport\} END; ResetObject(h); END; END; BEGIN DCPref := GetPref(544);{get status of drawing coordination} SetPref(544,FALSE);{turn off drawing coordination} ReDrawAll; {•••• Ask for starting number ••••} numberStr := StrDialog('Enter and INTEGER to start numbering:','1'); Message('Click in empty space to end numbering'); SetVPNumber; {•••• Repeat process until there is NO object at the clicked location ••••} WHILE GetPickObjectInfo(pX,pY,h,h2,dummyVar) DO BEGIN SetVPNumber; END; ClrMessage; {ReDrawAll;} SetPref(544,DCPref);{set drawing coordination to original state} zoomis:=GetZoom; SetZoom(101); Setzoom(zoomis); END; RUN(NumberVPConsecutive); vp renumber.vwx Quote Link to comment
michaelk Posted November 7, 2022 Share Posted November 7, 2022 I get it in my VP renaming script, too. I got it to work by first running it with values I KNOW aren't already used, then running it again with values I want. Then I went back to the original way and just clicked OK at the VS error and it works anyway. Quote Link to comment
