bjoerka Posted November 3, 2022 Share Posted November 3, 2022 I just started to use or i am trying to use Vision, but without any success. After opening an export from vectorworks (commend send to vision) i can only do two or three things inside vision and than the spinning ball appears. I am running a Macbook Pro 16" with M1Max CPU and MacOs12.6. Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted November 4, 2022 Vectorworks, Inc Employee Share Posted November 4, 2022 I had this issue when migrating from an older version of Vision, try a repair or fresh re-install. Any further issues, contact tech support directly. Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted November 4, 2022 Vectorworks, Inc Employee Share Posted November 4, 2022 Can you post the Vectorworks File that you are trying to send? 1 Quote Link to comment
Vectorworks, Inc Employee klinzey Posted November 4, 2022 Vectorworks, Inc Employee Share Posted November 4, 2022 Make sure you run the Vision Library updater. We had had some reports of issues with specific fixtures and have updated the fixture library to correct the problem. 1 Quote Link to comment
bjoerka Posted November 4, 2022 Author Share Posted November 4, 2022 @klinzey - i guess your suggestion solved the problem. after updating the fixture libraries it does not freeze anymore. thanks! 1 Quote Link to comment
