jpccrodrigues Posted November 3, 2022 Share Posted November 3, 2022 Hi, We've been (trying) to use the new site modifiers from VW 2023. It's a work in progress... It's a new approach, it takes time. In this process, we think that we are facing a bug/error regarding the site modifier transversal profiles. When we add it, it just goes a small portion of the path profile. If someone can take a look at the file attached and verify if there is some error from our part (site model creation, site modifier etc) or if we in fact have a bug, we would be thankful. Regards, SITE_MODIFIER_TRANSVERSE_PROFILE.vwx 1 Quote Link to comment
Zsombor Posted December 1, 2022 Share Posted December 1, 2022 HI, it doesn't work for me either. Nothing happens when I want to add a transversal profile. Can anyone help with it? thx Quote Link to comment
Zsombor Posted December 2, 2022 Share Posted December 2, 2022 If you open a metric blank file, it works fine. With my own template file it doesn't. strange Quote Link to comment
jpccrodrigues Posted December 6, 2022 Author Share Posted December 6, 2022 Hi, good morning, @Zsombor thanks for your help. We did our test and worked as well. And the solution creates another problem... putting the drawing close to the origin (the point that solved the problem), we loose the georeferenced features. Either we have site model or georeferenced features... Another point to sign: in medium-complex site models, cut and fill calculations are impossible. 6 hours and nothing. Vectorworks should really look at the stability of the new site model workflow and present webinars ASAP so we can assess if we are facing bugs (and you can identify a lot of them corrected in the last SP2) or if it is only adaptation to a new way to work. Quote Link to comment
Anders Blomberg Posted December 6, 2022 Share Posted December 6, 2022 @jpccrodrigues Did you try to relocate the internal origin close to the geometry rather than moving the geometry to the origin? Setting an internal origin allows you to keep the georefed origin, it's how I set up all my models, otherwise I run into all sorts of weird issues. Quote Link to comment
