Hunter B Posted February 8, 2005 Share Posted February 8, 2005 It's not so much the time it takes to render each frame of the annimation... it's the time it takes to get from the end of one frame to the begining of the next frame. I can see the rendering bar skip along fairly fast but the time it takes to get to a new rendering bar is aweful. javascript:void(0) Eek! The frame can render in about 4 - 5 minutes but the switch over can take up to 13 minutes. Does anybody else run across this issue?? Is there something I can do to speed this along??javascript:void(0) Confused Quote Link to comment
islandmon Posted February 14, 2005 Share Posted February 14, 2005 There are many versions of Java include java3D. Your code is requesting a java class that is not in your library. Therefore, the JV eng is programmed to recursively search your entire directory...taking about 13 minutes onyour disk. I recommend upgrading your Java and including the 3D package. Quote Link to comment
Hunter B Posted February 14, 2005 Author Share Posted February 14, 2005 THANK YOU!!!!! You saved me a TON of rendering time!!!! If you are ever in San Francisco I'll buy you a beer or three... maybe a Mojito! Quote Link to comment
mike m oz Posted February 15, 2005 Share Posted February 15, 2005 islandmon Can you please satisfy my curiosity as to how this interacts with the animation process in VectrorWorks. If it does speed up the animation process I too will buy you a beer or three if you are ever in this part of the world. PS - I am on a mac Quote Link to comment
B.Balemi Posted February 15, 2005 Share Posted February 15, 2005 Me too the New Zealand beer is better as well. Im on pc Quote Link to comment
Hunter B Posted February 16, 2005 Author Share Posted February 16, 2005 Ya'll won't believe this but I finally finished a 30 second annimation and handed it off to our video department and they asked "why the hell is the file so big???" We deduced that the annimation was rendered at SCREEN resolution...DOH!.... I guess I never really knew that, so I lowered my screen resolution and reduced the size of the initial rendering frame and ran the same annimation for a test. The original took 7 days to render the 2nd attempt at a lower resolution took only 1.5 Days. THANKS for all the help! Quote Link to comment
