kosbax Posted November 1, 2022 Share Posted November 1, 2022 Ιn the previous version of VW (Connectcad) it was possible to change the view, and edit, the position of the rear devices on the rack, as selectable button. In the new version, I don't see this possibility. Could you give me some advice on how to do this in the new version (2023)? Thanks Kostas Bax Quote Link to comment
Vectorworks, Inc Employee Conrad Preen Posted November 2, 2022 Vectorworks, Inc Employee Share Posted November 2, 2022 Hi Kostas, Yes there have been some changes. Mounting front / rear is controlled in the Object Info Palette - select the equipment item and use the Mounting popup. Visibility is set by class. All ConnectCAD objects are in classes that begin with "CC-" so take the opportunity to explore a bit in the Nav Palette and see what's available. You can "skin" your document by editing the class attributes (colour, line style etc.) and if the class contains text then class text styles are also applied. Cool thing is that you can override class attributes in viewports so you can create a print version for example that looks different from the design layer. Lots of new stuff to get used to 🙂 Enjoy Conrad Quote Link to comment
kosbax Posted November 4, 2022 Author Share Posted November 4, 2022 Thanks Conrad Preen, you are very good, All its clear Kostas Baxevanis AV Systems Engineer 1 Quote Link to comment
