Ramon PG Posted October 31, 2022 Share Posted October 31, 2022 I am a bit confused with wall visibilities. Used to be by class, but now attribute classes also affect it. Quote Link to comment
Tom W. Posted October 31, 2022 Share Posted October 31, 2022 Can you explain a bit more what you mean...? You have the overall container class then the sub-classes for the individual components... Quote Link to comment
Ramon PG Posted October 31, 2022 Author Share Posted October 31, 2022 Walls now have styles and when I change the class to GB-Low, so it will not show in Reflected Ceilings, the internal classes in the wall seem to override the general class I gave them. Quote Link to comment
Ramon PG Posted November 1, 2022 Author Share Posted November 1, 2022 10 hours ago, Tom W. said: Can you explain a bit more what you mean...? You have the overall container class then the sub-classes for the individual components... The container class dominates over the subclasses? If so, I must have a bad setting. Quote Link to comment
Jeff Prince Posted November 1, 2022 Share Posted November 1, 2022 It's not possible to answer your question with the information provided. So much depends on the container class (where you place the wall), where it exists (design layer and/or story), component classes, display type (plan, horizontal section, etc), and where the cut plane is. I recommend reading the entirety of the help menu in regards to walls and then watch the Vectorworks University course on the firehouse remodel IIRC with wall data visualizations to get a good handle on what you are create and how to deal with it. https://app-help.vectorworks.net/2022/eng/VW2022_Guide/Walls/Creating_walls.htm#h 1 Quote Link to comment
Ramon PG Posted November 1, 2022 Author Share Posted November 1, 2022 10 hours ago, jeff prince said: It's not possible to answer your question with the information provided. So much depends on the container class (where you place the wall), where it exists (design layer and/or story), component classes, display type (plan, horizontal section, etc), and where the cut plane is. I recommend reading the entirety of the help menu in regards to walls and then watch the Vectorworks University course on the firehouse remodel IIRC with wall data visualizations to get a good handle on what you are create and how to deal with it. https://app-help.vectorworks.net/2022/eng/VW2022_Guide/Walls/Creating_walls.htm#h Thank you for the guide. I will definitely read it. 1 Quote Link to comment
