ArenaLights Posted August 15, 2001 Share Posted August 15, 2001 Version 9 spotlight When ganging instruments together I have noticed that the two-fer line is showing through the hexagonal container are there any setting to make this not happen? Or is ther any way to edit the two-fer line so it stops at the container and allows easier reading of the contents of the container? Thank You Tlaloc Lopez-Watermann Quote Link to comment
kacey1 Posted August 15, 2001 Share Posted August 15, 2001 I don't see this here on either my WIN or MAC copy of SpotLight. The hexagon is definitely on top of the two-fer lines. One thing to check-from the resources pallette, open the containers folder, and edit the 2d portion of the symbol. With the hexagon selected make sure on the attributes pallete the fill is set to solid, not none. Let me know if that fixes the problem. Sincerely ------------------ Kacey Fisher Quality Assurance Specialist Integrated Products Group Nemetschek North America Quote Link to comment
ArenaLights Posted August 15, 2001 Author Share Posted August 15, 2001 Yes this did it, thank you! I was unaware that the two-fer function was using containers as would a light. is it? wierd that the container did not com with a solid fill. Tlaloc Quote Link to comment
kacey1 Posted August 15, 2001 Share Posted August 15, 2001 Yes, the two-fer uses the same containers as you have assigned in the label legend. It is strange that they did not come with a solid fill, because that is how they shipped; my install here was that way. But, I guess now you know how to fix it so... ------------------ Kacey Fisher Quality Assurance Specialist Integrated Products Group Nemetschek North America Quote Link to comment
