Plant Tag Alignment
Hi again.
I am struggling with aligning my plant tags automatically.
I have a plan that has over 30 species of plants set out in a cottage garden style.
I have always had trouble aligning the plant tags as they almost always crossover and are spaced apart at a spacing that I don't want. So I am always tweaking them or just giving up and doing it manually.
What am I missing?
The current plan:
First try at aligning is
I am drawing my alignment line where the pink line is every time. This is the result.
Nowhere near the line I drew. All bunched up and crossing lines.
Second attempt: No better.
This was a bit better. But still crossed lines and no where near where I drew my line.
I could keep going with configurations, but a similar outcome.
THANKS IN ADVANCE.
  • 1 month later...
I'm currently annotating a planting plan and having to deal with this...
I always plan on doing a first pass a little bit wider than I want for the final.
That way I can see which lines are crossing and then very roughly stack them in the right order.
Note - if you do the first pass too wide then the leader line crosses will be all over the place - the key is to do just wide enough that you have room to manually resort the offending leader lines.
In the second pass I align distribute they seem to get much closer with maybe only one or two crossing lines that I adjust manually.
And in the third pass I align the labels (we like groups to be all vertical).
Quick note about spacing in case you hadn't read this before - the tool uses the spacing between the top 2 tags when using "equal distance between shoulder lines"
Second quick note - I just put up a wish list to add presets to this very useful, but not quite perfect tool!
Thanks. I did not know about the spacing of the top 2 tags. This will also help a lot.
