Boh Posted October 28, 2022 Share Posted October 28, 2022 (edited) Hi there. Can someone please tell me why wall components are not showing in 3d views on some walls? I've tried the eyedropper but no joy. I've just upgraded to vw2023. The images below are of a wall junction of two walls of the same style but only one is showing the lining in 3d. Edited October 28, 2022 by Boh Quote Link to comment
FBernardo Posted October 28, 2022 Share Posted October 28, 2022 Hi @Boh Would it be possible to see the file? The plan view in Hidden line is it through Viewport or in the Design Layer Space? Quote Link to comment
Boh Posted October 28, 2022 Author Share Posted October 28, 2022 It’s in the design layer. Quote Link to comment
FBernardo Posted October 28, 2022 Share Posted October 28, 2022 2 hours ago, Boh said: It’s in the design layer. I can't think of anything to make just some components disappear, would you be able to take a screenshot of the wall make up, and the settings of your classes? Quote Link to comment
Boh Posted October 29, 2022 Author Share Posted October 29, 2022 Thanks. I’ll take some screenshots when I’m back on the PC. However if the walls are the same style and both use component attributes for rendering and component attributes are all set by class then I can’t think why one wall should display 3D components and the other not. The file was converted from a v2019 file to v2023 so I wonder if that is the problem? Quote Link to comment
FBernardo Posted October 29, 2022 Share Posted October 29, 2022 5 hours ago, Boh said: The file was converted from a v2019 file to v2023 so I wonder if that is the problem? This is possible to happen in conversions... i could say, try to break the join of the walls and see if all the components show? Quote Link to comment
Boh Posted October 31, 2022 Author Share Posted October 31, 2022 So it looks like breaking the wall joins as well as deleting wall peaks and end caps - then redoing them, seems to have worked. Had to play around with it for a while and got some really weird behavior in the process with only one side of the wall lining showing in 3d at one point. There is a bug somewhere but don't ask me where! Thanks for your help @FBernardo. Thanks Quote Link to comment
FBernardo Posted October 31, 2022 Share Posted October 31, 2022 3 hours ago, Boh said: So it looks like breaking the wall joins as well as deleting wall peaks and end caps - then redoing them, seems to have worked. Had to play around with it for a while and got some really weird behavior in the process with only one side of the wall lining showing in 3d at one point. There is a bug somewhere but don't ask me where! Thanks for your help @FBernardo. Thanks I believe if you don't use the END CAPS the walls just join properly, i would share here your file and let them check it, because it already happened to me before, but i could never reproduce it so i never filed a report. Quote Link to comment
