Mauro Pujia Posted October 27, 2022 Share Posted October 27, 2022 Hi Since VWX 2022 I'm having issues with my template label legends. The 2d symbol seems to be arranged correctly but when applying it to a lighting device it gets corrupted, screenshots above: , Quote Link to comment
MrTemplate Posted October 27, 2022 Share Posted October 27, 2022 Hi Mauro; I'm a bit confused by your screen shots, i'm not sure what portion of the label legend is appearing properly, and which part is "corrupted." in the top screen shot it looks like the "channel" data text needs to be "widened," so that the number doesn't potentially word-wrap? and the "universe" data text needs to be both "wider" and a larger font size to equal the font size of the DMX address and the channel texts? can you add a third shot showing the same [or similar] label legend appearing correctly? Quote Link to comment
Mauro Pujia Posted October 28, 2022 Author Share Posted October 28, 2022 Hi MrTemplate Sharing some screenshots explaining the hole situation visually, probably best way to fully explain it. hace 17 horas, MrTemplate dijo: Hi Mauro; I'm a bit confused by your screen shots, i'm not sure what portion of the label legend is appearing properly, and which part is "corrupted." in the top screen shot it looks like the "channel" data text needs to be "widened," so that the number doesn't potentially word-wrap? and the "universe" data text needs to be both "wider" and a larger font size to equal the font size of the DMX address and the channel texts? can you add a third shot showing the same [or similar] label legend appearing correctly? Quote Link to comment
MrTemplate Posted October 28, 2022 Share Posted October 28, 2022 Hi Mauro; thanks for your screen shots. 1] are the "containers" in the container folder? and, if i'm not out of touch, the size of the containers are finite, right? that is, they can't expand their size, if the data inside the container is larger than the edge of the container? also, 2] are the data fields aligned? it would seem like the "DMX Address" data field needs to be aligned to the right edge of its container, while the "Universe" data field needs to be aligned to the left edge of its container, so the two would not overlap? 1 Quote Link to comment
