Help - Drawing polygons with specific angles
Is there a way to draw a polygon (6-8 sided shapes) to the exact angles you want as you draw it?
Eg. Draw a straight line then click to draw the next line, which I want to be at 65degrees to the previous line, then the next line to be at 120degrees etc .
Issue being the angles shown in the drawing window are relative to xy axis rather than in relation to the line I just drew so I have no control over the angles I am creating as I go.
Any way to change this????
