Projx_CA Posted October 20, 2022 Share Posted October 20, 2022 (edited) I'm trying to insert a truss bridle with the "Reverse Two Leg Bridle" tool - but BW seems to think there is a chain under pressure and keeps failing. Disabling Second order analysis returns a weight value of 0 lbf on the centre hoist. A simple truss, with 2 points calculates without issue. However, once I add the centre inverted bridle BW fails. What am I doing wrong? Is this not the intended use of this tool? @JustinVH @jcogdell Edited October 20, 2022 by Projx_CA Quote Link to comment
Projx_CA Posted October 25, 2022 Author Share Posted October 25, 2022 (edited) @Moritz Staffel Do you have any ideas or suggestions on how to properly apply a reverse truss bridle? Is there correct way to implement this tool? I've followed this process from the 2022 Help: Quote If inserting a reversed two leg bridle, do the following. If inserting any other bridle type, proceed to step 5. Click on the rigging object to set the insertion point for Leg 1, and click again to set the insertion point for Leg 2. The available insertion points are highlighted as the mouse moves over them. Click on the rigging point where the bridle will attach. Valid insertion points are highlighted as the mouse moves over them. The bridle object is inserted in the drawing. Move the mouse to the object that the bridle will support, and click to set the connection point. Valid connection points are highlighted as the mouse moves over them. Insert the bridle legs. For each leg, click on the rigging point where the leg will attach. The available insertion points are highlighted as the mouse moves over them. The bridle object is inserted in the drawing. Edited October 25, 2022 by Projx_CA Quote Link to comment
Mark Aceto Posted October 25, 2022 Share Posted October 25, 2022 I fought with the reverse 2 leg bridle on a gig earlier this year using VW 2022. There have since been improvements to this tool that might help you out in VW 2023. I haven't tested it yet but it's worth a shot. Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted October 26, 2022 Vectorworks, Inc Employee Share Posted October 26, 2022 This is not working as expected for me in 2023 either. Posting a bug report about it. 1 Quote Link to comment
Projx_CA Posted October 26, 2022 Author Share Posted October 26, 2022 Thanks to you both for responding - my default position is that I've messed it up somehow, so I appreciate your time and individual experiences. Mark, I'm always reluctant to upgrade before a service pack update for the reasons you've posted in other 2023 topics - yikes!. Scott, thanks for saving me the time to do so. I was about to upgrade to see if it had been fixed. Best Regards, Charles 1 Quote Link to comment
Mark Aceto Posted October 27, 2022 Share Posted October 27, 2022 5 hours ago, Projx_CA said: Mark, I'm always reluctant to upgrade before a service pack update for the reasons you've posted in other 2023 topics - yikes!. As an option, you can install the new version to get to know the new features until you're ready to use it in a production environment. SP 2.1 is typically *chef's kiss* sometime before the end of the year. 1 Quote Link to comment
