Mark Aceto Posted October 20, 2022 Share Posted October 20, 2022 Not sure what's causing this but I have to find and delete the duplicates: Quote Link to comment
Pat Stanford Posted October 20, 2022 Share Posted October 20, 2022 Maybe a worksheet of Truss Crosses. Fields for the X, Y Z position. Sort on the positions. Should be relatively easy to see the duplicates with the same (or even close) locations in the list. Quote Link to comment
Kevin Allen Posted October 20, 2022 Share Posted October 20, 2022 select coincident objects? Quote Link to comment
Mark Aceto Posted October 20, 2022 Author Share Posted October 20, 2022 There are A LOT of them, and I'm wondering what is causing this issue (other than a bug) because that could be a clue to the errors I'm trying to fix. Also, they reproduce quickly on their own. Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted October 21, 2022 Vectorworks, Inc Employee Share Posted October 21, 2022 @Mark AcetoI've had a look at your file and as far as I can tell the issue is being caused by the lower layers of unistrut being too close together, I found moving them each about an inch apart stops the duplicate truss crosses being created. I've Dm'd you a fixed version of the file 1 Quote Link to comment
Mark Aceto Posted October 21, 2022 Author Share Posted October 21, 2022 5 hours ago, jcogdell said: @Mark AcetoI've had a look at your file and as far as I can tell the issue is being caused by the lower layers of unistrut being too close together, I found moving them each about an inch apart stops the duplicate truss crosses being created. I've Dm'd you a fixed version of the file Thanks, Jesse! That makes sense. I've noticed that with any rigging elements, literally anything with a pixel (even truss cross labels) can throw off VW/BW, so that's a good note for anyone following this. Hopefully, I won't have too many 41mm strut to 41mm strut connections but I've already 2 gigs with that in the past 2 months, so... As a solution / workaround, I'm wondering if I can create custom truss cross symbols that smaller/thinner and won't clash with each other. I guess then I would pick that symbol in the Insert Connection settings before connection any rigging objects. I thought there was a way to scale them but I can't find it. Quote Link to comment
Vectorworks, Inc Employee JustinVanHassel Posted October 21, 2022 Vectorworks, Inc Employee Share Posted October 21, 2022 If you change the offset of the truss cross symbol in the record it will change the thickness. You may have to adjust the insertion point but I thing you can go down to 1mm of offset if you need a really thin connection. You will also have to adjust the 3D extrude thickness of the symbol that you make to get the visual to not clash. Quote Link to comment
