Ramon PG Posted October 20, 2022 Share Posted October 20, 2022 I am trying to make a wall tag with a simple marker for each wall type (eg. "A" for gypsum board , "B" for CMU, etc.) and then have a worksheet explain what each letter in the tag stands for. How can I have the wall tag display a simple marker instead of the whole wall description? Would I need to create/edit a Create Data Tag Style, or is there one ready-made in Resource Manager (that I can't find)? Thanks. Quote Link to comment
Tom W. Posted October 20, 2022 Share Posted October 20, 2022 The various 'Mk' tags in the libraries will return the 'Mark' field of a Wall Style. So enter 'A', 'B', etc in this field (Data tab) for each of your wall styles + delete the 'Note' part of the tag if you don't need this. Then in your worksheet report on the Mark field in one column + the wall style name or the 'Description' field or wherever it is you're taking the description of the wall from. 1 Quote Link to comment
Ramon PG Posted October 21, 2022 Author Share Posted October 21, 2022 22 hours ago, Tom W. said: The various 'Mk' tags in the libraries will return the 'Mark' field of a Wall Style. So enter 'A', 'B', etc in this field (Data tab) for each of your wall styles + delete the 'Note' part of the tag if you don't need this. Then in your worksheet report on the Mark field in one column + the wall style name or the 'Description' field or wherever it is you're taking the description of the wall from. Thanks, that worked perfectly. Can I automaticaly annotate the tag with the actual wall height? I have a same wall style with different wall heights (up to ceiling, up to slab...) Quote Link to comment
Tom W. Posted October 21, 2022 Share Posted October 21, 2022 2 hours ago, Ramon PG said: Can I automaticaly annotate the tag with the actual wall height? Yes the Worksheet Functions 'WALLOVERALLHEIGHT' or 'WALLAVERAGEHEIGHT' will return the height of a Wall 1 Quote Link to comment
Ramon PG Posted October 31, 2022 Author Share Posted October 31, 2022 On 10/21/2022 at 11:09 AM, Tom W. said: Yes the Worksheet Functions 'WALLOVERALLHEIGHT' or 'WALLAVERAGEHEIGHT' will return the height of a Wall I was able to add the WALLOVERALLHEIGHT to the worksheet and it works perfectly, but I have several walls that are the same construction except for the height. I was hoping to get the Tag to show the height automatically as it does in the Worksheet so that I don't have to do it manually one by one. For example... Quote Link to comment
Tom W. Posted October 31, 2022 Share Posted October 31, 2022 43 minutes ago, Ramon PG said: I was able to add the WALLOVERALLHEIGHT to the worksheet and it works perfectly, but I have several walls that are the same construction except for the height. I was hoping to get the Tag to show the height automatically as it does in the Worksheet so that I don't have to do it manually one by one. For example... I'm not sure what you mean. You can use the worksheet function in the data tag: Then if desired insert using All Eligible Objects Mode to tag all walls at once. Quote Link to comment
Ramon PG Posted October 31, 2022 Author Share Posted October 31, 2022 (edited) I Edit Tag Layout I add the text in Tag Layout I define the Tag with Document Units I get rounded results with 10" instead of 10'-2" and 9" instead of 8'-6" Edited October 31, 2022 by Ramon PG Quote Link to comment
Tom W. Posted October 31, 2022 Share Posted October 31, 2022 Hmm I am getting the same thing when I change my Doc Units to Feet + Inches. Ironically if I have my Doc Units set to millimetres (which I normally do) but ask the tag to display in feet + inches the height displays correctly as 10'2". Other times I'm getting either 10" like you or 10 1/8"... Seems like a bug but perhaps someone else more familiar with using imperial can test as well... 1 Quote Link to comment
Ramon PG Posted October 31, 2022 Author Share Posted October 31, 2022 I added *12 after the formula for Feet and Inches and it works. Must be a bug. 1 Quote Link to comment
