Door structural opening / screed
PiotrS
My Workaround.
- Make the Door Height = door height + floor height.
  (to cut the Wall "beneath" your Door)
- Give Door a Z Offset (- floor height)
- In Door Style activate and assign a suitable "Threshold" with floor height
  (to keep the bottom of Door Leave above the Floor))
- Assign a hidden Class to Threshold to make it invisible
- Draw a Rectangle iside the Door cut out on Layer Plane
- Convert Rectangle to Object = Slab (of your desired Floor Package Style)
Mandatory :
- To model with separate Structural Slab vs Flor Package Slabs
(which you usually will have when having different Floor Materials for your Rooms)
Edited by zoomer
Thank you Zoomer,
I have found a similar workflow, but with Door Height = Door Height from FFL.
1- Threshold Z Offet = - (minus) floor height
2 - Threshold on invisible classes without graphic attribute
3 - in door preference set up in 2D and Classes choose special class for Thresholed429820773_Screenshot2022-10-20at20_20_52.thumb.png.98c8dde72eae1bebdab1c37d9b341d40.png
  • Like 3
