not responding
I have been trying to delete a drawing in a design layer but VW 2020 fails to respond. I restart VW and try again but to no avail. How can I fix this?
The drawing is a 2D site plan and is in a group. I have tried deleting the group or going into the group to delete the site plan or delete the site plan layer. Each time VW is not responding.
Any suggestions appreciated.
I had this happen once before due to importing a dirty .dwg.
My solution was to copy each design layer to a new VWX file and rebuild it because nothing else cured the issue, not optimal if you have a bunch of sheets and viewports already set up.
Perhaps you can reach out to VWX tech support and see if they can work some magic?
