if condition to change the value of a planar/solid boolean
Raph
Hello everyone,
I would like to change the state of a planar/solid boolean depending on a condition.
More precisely, I would like to be able to remove or not a square to an existing volume. The condition is true or false.
I thought I could do this with an "if" by acting on the size of the square.
if true = 3mm
if false = 0mm
but it creates an error
Does anyone have a solution for me?
Thanks in advance
greetings
Raphael
test Forum.vwx
Hi Pat,
Thank you for your answer.
Unfortunately, this postpones the problem to the next step. The next node is a planar boolean. But an empty boolean operation also creates an error.
Is it possible to create a planar boolean node with a configurable "add, sub, ..." input.
Has anyone ever created a node like this?
Hello,
i think the solution of @Pat Stanford is working when the "False" value of the "If" node is "vs.Handle(0)" (take a "Any" node and write "vs.Handle(0)" into it).
I tested it with 2 rectangles, my Marionette looks like this:
340862378_Bildschirmfoto2022-10-20um17_12_26.thumb.png.d9b23e29a7fad853d052b4fad9185045.png
I tried to find an explanation for this behaviour, but i think i will leave it to the experts ☺️
Regards,
Letti
Hi Letti,
Thanks for your reply.
unfortunately it doesn't work properly
it seems that the created surfaces don't really get deleted
Has anyone ever created a boolean node with an extra entry that would allow to act on the action of the boolean?
Add, substrac or intersection
Thanks in advance
Hi everyone,
I'm thinking about something like this...
but I don't know enough python to do it by myself yet
@Marionette.NodeDefinition
class Params(metaclass = Marionette.OrderedClass):
#APPEARANCE
    #Name
    this = Marionette.Node( "Planar Boolean" )
    this.SetDescription('This node performs a boolean operation between lists of objects. The operation will be performed for each possible combination of objects in the lists supplied.')
    #Input Ports
    in0 = Marionette.PortIn( vs.Handle(0), 'hBlank' )
    in0.SetDescription('A list of objects to be operated on (blanks)')
    in1 = Marionette.PortIn( vs.Handle(0), 'hTool')
    in1.SetDescription('A list of objects to operate on "in0" with (tools)')
    in2 = Marionette.PortIn(vsHandle(0), 'hValue')
    in2.SetDescription('A list of operation _ 0=Add _ 1=Substract _ 2=Intersect')
    #OIP Controls
    op = Marionette.OIPControl( 'operation', Marionette.WidgetType.Popup, 0, ['Add', 'Subtract', 'Intersect'])
    op.SetDescription('The operation to perform between objects\n'
                        '   Add: equivalent to the "Add Surface" command in VW\n'
                        '   Subtract: equivalent to the "Subtract Surface" command in VW\n'
                        '   Intersect: equivalent to the "Intersect Surface" command in VW')
    #Output Ports
    out = Marionette.PortOut('hObj')
    out.SetDescription('The resulting objects')
#BEHAVIOR
    this.SetLinksObjects()
    this.SetListAbsorb()
def RunNode(self):
    #inputs
    in0 = self.Params.in0.value
    in1 = self.Params.in1.value
    in2 = self.Params.in2.value
    #script
    output = []
    if type(in0) != list:
        in0 = [in0]
    for blank in in0:
        if blank != vs.Handle(0):
            if type(self.Params.in1.value) != list:
                in1 = [in1]
            for tool in in1:
                newObj = vs.Handle(0)
                if tool != vs.Handle(0):
                    #Add
                    if self.Params.op.value == 0:
                        newObj = vs.AddSurface(blank, tool)    # blank and tool will be deleted after this operation
                        if newObj != vs.Handle(0) and newObj != None and newObj != tool:
                            blank = newObj
                    #Subtract
                    elif self.Params.op.value == 1:
                        newObj = vs.ClipSurfaceN(blank, tool) # blank and tool won't be deleted after this operation
                            vs.Marionette_DisposeObj(blank)
                            vs.Marionette_DisposeObj(tool)
                            blank = newObj
                    #Intersect
                    elif self.Params.op.value == 2:
                        newObj = vs.IntersectSurface(blank, tool) # blank and tool won't be removed after this opeartion
                            blank = newObj
            while blank != vs.Handle(0):
                if self.Params.op.value in [1, 2]:
                    if blank != tool:
                        output.append(blank)
                else:
                blank = vs.NextObj(blank)
    #outputs
    self.Params.out.value = output
Hello,
unfortunately i cant figure out if your Marionette is working correctly, because it is quite complicated, but i think a simple "Delete" node right behind the "Rectangle" node could do the trick.
But i also wrote the node you were looking for, or at least i think so:
#APPEARANCE
	#Name
	#Input Ports
	n_action_in = Marionette.PortIn( 0, 'nAction' )
	n_action_in.SetDescription( '0 = Add, 1 = Subtract, 2 = Intersect' )
	#OIP Controls
	#Output Ports
#BEHAVIOR
def RunNode(self):
	#inputs
	n_action = self.Params.n_action_in.value[0]
	#script
	output = []
		in0 = [in0]
	for blank in in0:
				in1 = [in1]
			for tool in in1:
					#Add
					if n_action == 0:
							blank = newObj
					#Subtract
					elif n_action == 1:
							blank = newObj
					#Intersect
					elif n_action == 2:
							blank = newObj
				if n_action in [1, 2]:
					if blank != tool:
				else:
	#outputs
If you need, i could also add a "Do nothing"- action to this node, where the "hBlank" is put out of the node unchanged and the "hTool" object gets deleted?
Regards,
Letti
Hi Letti,
Thanks a lot for your complements and for the planar boolean node!
Your code works well and I also adapted it for a solid boolean.
So I tried the following two variations:
1. to put a "delete" after the rectangle
2. to put the planar boolean node with parameters
in fact both solutions created the same problems.
I realized that my approach was wrong.
Instead of working with a boolean node for each element to be subtracted/added, I need a boolean node and send only the shapes that need to be subtracted.
Sorry Letti, I didn't understand where the error came from.
attached is a printscreen of the working solution (with a single boolean planar node)😉
Best regards
Raph
Edited by Raph
