Unless I am mistaken there is no current way of using the autnumbering tool to make stairs start at any number other than 1. Ideally, this should be customisable so the stairs from Level 1 to Level 2 will be numbered 1-16, and then the stair from Level 2 - 3 will be numbered 17-32 and so on.
Presently we have the tedious task of numbering stairs manually, which is fine until the number of treads or even the depth of tread changes and everything needs adjusting! I do appreciate stairs can just be numbered from 1 for each level, it just doesn't comply with the Directors preferences!
Josh S
4 answers to this question
